Is it possible to delete a Parameter in the Interface?
I've created an empty subnet, which comes with the four inputs. I want to keep only two and delete the other two, HOWEVER I could find a way to delete these two parameters?? Note: If I dive inside the subnet and tries to delete these inputs (i.e. select them and press "delete") they won't get deleted! and If I right click on the subnet and bring up "Edit Parameter Interface", I don't see any "delete button", the max I can do is hide these two parameters? Is this normal or am I doing something wrong?
Thanks,
