catchyid Posted March 30, 2017 Share Posted March 30, 2017 Hi, According to Houdini Docs: in a DOP network, grey input is an object, green input is object + data. I have not seen an explanation for DOP magenta inputs, ie. what do they mean? Quote Link to comment Share on other sites More sharing options...
3dome Posted March 30, 2017 Share Posted March 30, 2017 from the docs: Pre-Solve (first magenta) Microsolvers attached to this input will run before the main solve step. For example, a SOP Solver can be used to modfiy the object’s geometry, and POP force nodes can be used to apply forces to specific objects. Post-Solve Microsolvers attached to this input will run after the main solve step. 1 Quote Link to comment Share on other sites More sharing options...
catchyid Posted March 30, 2017 Author Share Posted March 30, 2017 Thanks for your help, I found that help section I was thinking, maybe there was a generic definition for ALL connections of that magenta color, like the same way they define the meaning of grey and green inputs .... Quote Link to comment Share on other sites More sharing options...
