Cookie not intersecting geometry properly
houdini1987
Geometry A is open. It should be at least solid, for better results. Try to fill holes with PolyCap. And one of the cutters is probably bad. There is new Boolean node in H16. Much better than Cookie. It even cuts with bad cutter making proper "bad cut":
Edited by f1480187
Thanks F1. I will try with polycap. Saw H16 seminar and cookie looked promising in it. Currently have to finish this project in H15 only. But anyways thanks for the direction.
