jim c Posted April 8, 2017 Share Posted April 8, 2017 I've got a sky rig that I would like to cache to disk. But when I use a FileCache SOP at the end of the network, cache it, and then turn of the Load From File toggle, nothing comes back. Are there other steps I need to take to get this to work? sky-nocache.hipnc Quote Link to comment Share on other sites More sharing options...
David Jon Nelson Posted June 6, 2017 Share Posted June 6, 2017 Did you ever figure it out? I'm running into the same problem as well. Quote Link to comment Share on other sites More sharing options...
Atom Posted June 6, 2017 Share Posted June 6, 2017 That does seem odd. What you can do is instead of using the FileCache node just use a File node in Write mode and simply play the timeline. I threw in a convert of the volumes to VDB and set the File node to write VDB instead of .bgeo.sc. ap_sky-nocache(1).hipnc Quote Link to comment Share on other sites More sharing options...
