evanrudefx Posted April 9, 2017 Share Posted April 9, 2017 Hey, I am trying to get a ramp parameter to work in point vop. I can get ramps to work, but the ramp parameter I cannot get to work. I have included to photos. I am new to using point vops, so I really am not sure. I did look this up on google, but I could not find the solution. Thanks Quote Link to comment Share on other sites More sharing options...
konstantin magnus Posted April 9, 2017 Share Posted April 9, 2017 I think you confused the ramp node with the ramp parameter node. Quote Link to comment Share on other sites More sharing options...
evanrudefx Posted April 9, 2017 Author Share Posted April 9, 2017 On 4/9/2017 at 9:25 PM, konstantin magnus said: I think you confused the ramp node with the ramp parameter node. Expand I am trying to use the ramp param node because you have more control over the ramp. the ramps node has no control over the ramp it creates. Quote Link to comment Share on other sites More sharing options...
evanrudefx Posted April 9, 2017 Author Share Posted April 9, 2017 I am trying to do this, but I want to use the ramp param so I can control the ramp. Quote Link to comment Share on other sites More sharing options...
evanrudefx Posted April 9, 2017 Author Share Posted April 9, 2017 (edited) Actually, this is more correct. I want to fade out the noise like this: Edited April 9, 2017 by ejr32123 Quote Link to comment Share on other sites More sharing options...
evanrudefx Posted April 9, 2017 Author Share Posted April 9, 2017 I eventually came across the solution, thanks : ) Quote Link to comment Share on other sites More sharing options...
