Normals/Shading Issue
HainesAJ
I'm having trouble figuring out this phong/normals issue. The picture shows it best but I extruded a shell to give it some depth. On the edge I pointed the normals where I thought they needed to be but I'm still getting a weird shading issue. I'm not sure whats causing it. Any ideas how to fix this?
Thanks
AJ
put this point wrangle just before the extrude:
int neighs = neighbourcount(0, @ptnum);
if(neighs < 3)
    removepoint(0, @ptnum);
deletes the points (procedurally) so you get clean geo but doesnt fix the rendering issue. This comes from cusping the polygons. Do you need to cusp them?
EDIT:
fixing the geo with fuse nodes helps. see file
SphereBoole_EdgeProblem_v2.hipnc
Edited by 3dome
update
It's a shading error caused by light direction trying to be perfectly perpendicular to surface. Add a bit of inset for your extrude node or move light/geometry by a small distance from origin or try spherical light.
Edited by f1480187
typo
@3dome Wow that solution work pretty perfectly. Thanks so much. I'll have to look more into the science behind that neighborcount function, also the fuse node is new to me as well. All good stuff. Yeah the cusping is preferred. Thanks again for the help!
@f1480187 I see what you are saying. After 3domes fix the light didn't need to be moved after all. Thanks for the suggestions though:)
@HainesAJ, artifacts still there. Try to add a bit of contrast using bottom bar of Render View:
Fuse node recomputes affected points's normals by default. That results in slightly randomized normal directions from irregular topology in places where the new normals was computed. Extruding by such normals will output side surface non-perpendicular to light direction, reducing most of the artifacts. That's an equivalent of adding a bit of inset to extrude:
The difference is that the bumped surface will face the light and be lit, sunken surface will backface the light and be shaded. Randomized surface will be lit and shaded randomly.
Edited by f1480187
