KiLa Posted April 25, 2017 Share Posted April 25, 2017 Hi, i am trying to calculate angle and axis between two vectors, using the Align VOP.. I has an option to export 'Angle Axis' - its help card says: "This operator computes a matrix representing the rotation around the axes normal to two vectors (their cross product), by the angle which is between the two vectors. The resulting matrix maps the first vector onto the second. If both vectors have the same direction, the result will be an identity matrix. If the vectors are opposed, the rotation is undefined. This can also output a quaternion representation of the transformation rather than matrix." What does it mean? In the attached scene, i have an open circle which have some normals. Next i am trying to calculate the angle/axis between the normal an up vector, but the angles i get from the Align doesn't make any sense. Cheer -k angle.hipnc Quote Link to comment Share on other sites More sharing options...
f1480187 Posted April 26, 2017 Share Posted April 26, 2017 (edited) You still need to use Quaternion to Angle/Axis node after that. In result, you will get the axis multiplied by angle (in radians). Compute length to extract the angle. Normalize it (or divide it by length, same thing) to compute the axis. Alternatively, you can get axis by crossing vectors and normalizing the result and you can get angle by computing arccosine of dot product between vectors. quat_to_aavec.hipnc Edited April 26, 2017 by f1480187 Quote Link to comment Share on other sites More sharing options...
KiLa Posted April 26, 2017 Author Share Posted April 26, 2017 Haa, thank you Sir! Interesting tho - the length method seems to give 'wrong' angle for the first (0) point: 2.50448e-06. Whereas, the normal dot method gives the correct angle - 0. Quote Link to comment Share on other sites More sharing options...
f1480187 Posted April 27, 2017 Share Posted April 27, 2017 That's equal to 0.00000250448 in normal representation. Pretty common, you shouldn't expect numbers to evaluate into ideal values in Houdini, and everywhere floating-point arithmetic is used. Search for "floating point imprecision", you'll quickly get the basic understanding of the problem. Quote Link to comment Share on other sites More sharing options...
