H16 Solidify
Hmm after some digging through, I checked if the operator can be added using the opadd function in the texport.
As it turns out, the operator is still there (it even has a version 2!).
So next, I checked the OPcustomize file (located in your $HFS/houdini folder) where I found the it was intentionally hidden, and it comes with this note:
Quote
// For H16.0, the functionality of solidify has been replaced in favour of
// polyfill + boolean combo. Thus solidify 2.0 was made to expose only that
// functionality hole filing functionality of solidify that hasn't been yet
// replaced, however it is not currently used anywhere by us and we don't want
// to encourage others to use it. We do want to hide the old solidify from the
// users
ophide Sop solidify::2.0
ophide Sop solidify
If you still want to play around with the old solidify node, open up an Hscript Texport.
Then first go to your sop directory like so (assuming you have an existing geo1 object):
/ -> cd obj/geo1
Now, type this to create the solidify node:
/obj/geo1 -> opadd solidify
But notice that it would create the newer version of solidify (MMB on the node, to check the type and see solidify::2.0 under the name).
So type this instead to specifically use the old solidify:
/obj/geo1 -> opadd -e solidify
I hope this helps!
thanks...but strange that this doesn't mention anything about tet....ie. from the help link, I read it as a more advanced version of Tet SOP...
FYI, in the video, @ 00:11:40 shows new SOPs...why would they now hide it...
https://www.sidefx.com/tutorials/geometry-workflows/
EDIT: Maybe Solid Conform ? the Solidify sample file uses solidconform...(this is more on the Tet train of thoughts than the Polyfill school)
Edited by Noobini
You're welcome Vu :)
In my understanding, as mentioned in the docs:
Quote
Solidify is designed to aid the artist in tetrahedralizing a surface mesh using the Tetrahedralize SOP.
It is to aid - or help - the Tetrahedralize SOP. Because the Tet SOP needs a closed mesh.
Here's a portion from the Tetrahedralize SOP docs:
Quote
This operator is a low level tool that creates tetrahedralizations from closed and self-intersection free inputs.
The Solidy will close the mesh (which the PolyFill now does) which then aids the Tetrahedralize SOP to work more correctly.
Edited by galagast
