how to Edit alembic
If you middle click the node, you'll see that you have only one primitive, which makes sense with what you're saying.
If you put an unpack sop there, you'll see that you'll now have all points, but still no primitives. If you put a convert node set to polygons, then you'll have the geometry you're expecting (you can bypass the unpack if you so want).
  • 4 years later...
