Julien BOLBACH Posted May 11, 2017 Share Posted May 11, 2017 Hi guys, I'm trying to do the following on a geometry of points : - find the closest point to the first one, then iterate through this newly find point and find the closest one, etc. I'm trying to use nearpoint for that, by using the ptgroup. I create a group with all the points at the beginning, and through my loop, I remove the points found on this group. But it doesn't work, and I'm not sure what I'm doing right ... int neworder[] = {}; // start with point 0 int npt = 0; push(neworder,npt); // remove point from group setpointgroup(0,"points",npt,0); for(int i=0;i<10;i++){ vector p = point(0,"P",npt); // find nearest point from points group npt = nearpoint(0,"points",p); // remove newly point from group setpointgroup(0,"points",npt,0); push(neworder,npt); } i[]@points = neworder; I'm doing this on a wrangle node at the detail level (so only once). Any idea what I'm doing wrong ? Thanks, Julien Quote Link to comment Share on other sites More sharing options...
fencer Posted May 11, 2017 Share Posted May 11, 2017 Maybe better to use "findshortestpath"? Quote Link to comment Share on other sites More sharing options...
Maurits Posted May 12, 2017 Share Posted May 12, 2017 Hallo Julien I think you're current set up would return the same point every time it resulting in a array of 0's This is caused by the nearpoint function. This returns the first point it find near the provided coordinates with should be point 0. In addition you say to find the nearest point in the provided point group that only contains point 0. The following code should do what you wan't. int points_visited[]; // A list of points already visited int curr_point = 0; // current point to look from int max_distance = 100; // maximum search distance int max_points = 10; // max number of points to find vector P = point(0, "P", curr_point); //Stores the position of the points where looking from int handle; // variable for the point cloud for(int i = 0; i < 10; i++){ handle = pcopen(0, "P", P, max_distance, max_points); // Create a new point cloud containing all points in order from closest to farthest while(pciterate(handle)){ // Iterate over the point cloud pcimport(handle, "P", P); // Load new Position pcimport(handle, "point.number", curr_point); // Get point number if(find(points_visited, curr_point) < 0){ // See if point number is already in the visited array append(points_visited, curr_point); //if not add point to array pcclose(handle); // Close the PC break; // Stop the while loop } } } printf("%d\n", points_visited); Quote Link to comment Share on other sites More sharing options...
Julien BOLBACH Posted May 13, 2017 Author Share Posted May 13, 2017 Thanks ! I thought removing the point from the group would do the trick, but apparently it didn't ... Thanks again, its works well ! Julien Quote Link to comment Share on other sites More sharing options...
