art3mis Posted May 14, 2017 Share Posted May 14, 2017 From an earlier question here I can correctly output the wedge files. But when I try and render the actual flipbook using the comp node, all I get are black .jpgs. Can anyone look at the attached .hip (or the .hipnc from the above link) and tell me what needs to be changed to properly render the flipbook? also here wedge_flipbook1.hiplc Quote Link to comment Share on other sites More sharing options...
Jesus Nieto Posted May 17, 2017 Share Posted May 17, 2017 Hi Jim, I couldn't find the flipbook making option when I'm in COP's, how ever. I rendered the wedge node, and played it back from COP'S. looks fine, so if you just right click on COP's viewport and click "save sequence" you can save your comp to any image format you like and then bring it back to COP's. I tested it and the the sequence looks perfect. I don't know if this is what you wanted. Quote Link to comment Share on other sites More sharing options...
