Alexandre Posted May 17, 2017 Share Posted May 17, 2017 Hi everyone ! I need help for a project that I need to finish before next week, I have created a crack propagation (with VDB) on a simple geometry in Houdini, but unfortunately when I play the animation of the alembic exported file in Maya it makes crash the application… A workflow is described by Wayne Hollingsworth from gnomon here https://www.youtube.com/watch?v=RHLDS3SrZfs&t=3025s between 1:02:50 and 1:05:00 but once in Maya he uses Vray proxy import instead standard import to keep UVs. I share with you my houdini file (hiplc, h16), the alembic file size generated in houdini is under 100Mo As I am pretty new to houdini there are maybe some mistakes, if you see something wrong or if you have an idea to solve the problem, tell me thank you very much ! Alexandre calcification_v2.hiplc Quote Link to comment Share on other sites More sharing options...
Alexandre Posted May 20, 2017 Author Share Posted May 20, 2017 I managed to solved the problem by decreasing the speed of the animation Quote Link to comment Share on other sites More sharing options...
