catchyid Posted May 18, 2017 Share Posted May 18, 2017 Hi, I am reading a point cloud using "Point Cloud Open" VOP, so I am setting "Search Radius" and "Number of Points" to appropriate numbers, however I have a question: since this node is sampling a specific number of points in a certain radius, how does it calculate the final result? Meaning, If I set "Search Radius" to 0.5 and "Number of Points" to 10, then if the node finds 3 points 0.5 radius, how would it calculate the final result? I guess the most basic assumption is that it's going to average them? The documentation does not specify how this is done (http://www.sidefx.com/docs/houdini15.5/nodes/vop/pcopen). Quote Link to comment Share on other sites More sharing options...
Pazuzu Posted May 18, 2017 Share Posted May 18, 2017 (edited) The pcopen just give you a handle with the points sampled at a given radius; Then you can use another pc function like pcfilter to average the result of some data over the handle points, or you can use some pc combo functions like pciterate-pcimport to construct a loop over the handle. The pc arsenal is very usefull and is faster in some cases than using arrays. Cheers! Alejandro Edited May 18, 2017 by Pazuzu 1 Quote Link to comment Share on other sites More sharing options...
catchyid Posted May 18, 2017 Author Share Posted May 18, 2017 Thanks Alejandro Quote Link to comment Share on other sites More sharing options...
