Polyextrude Default Handle Align
lisux
Hi all.
I have seen that by default the PolyExtrude SOP handler is aligned to the world coordinates, but i think that is better, and more useful, to have it aligned to object by default.
How can i set by default object align for this tool?
Not using hscript, only the gui.
Thanks.
Hi all.
Thanks.
19610[/snapback]
RMB on the Handle & toggle the "Local Control" option.
Cheers!
steven
Cheers!
steven
19613[/snapback]
"Local Control" and "Handle World Align" don't seems to do the same,
with unchecking world align i can transform in object space so i can move along the surface normal direction, but with local control it seems that the handler doesn't use the local pivot, it uses a world pivot, these are different things i think.
