lemures Posted May 26, 2017 Share Posted May 26, 2017 Hello, In Houdini 16 is there a way to add a spring constraint to a Coth object. Want to simulate rope/cable anchors. A standard pin constraint with Soft doesn't feel like the cloth is tied down by rope and would also like to have that Max length parameter. Alternatively, if I can use a Wire simulation to be used as a spring constraint that would also work. However, my attempts at doing this have been disappointing. Wire sim would either become the dominate force by pulling the cloth down like a lead weight or the cloth with pull the wire like taffy, And large values were used in the wire setting to no avail. Any thoughts? -Thanks Quote Link to comment Share on other sites More sharing options...
