Linux + Hconsole + Cout?
I wonder how to show the Houdini's console in Linux. My custom SOP outputs info with cout or printf. Under Windows it works fine, but in Linux I don't see the Houdini's console. Actually, I don't see console when VEX outputs info too.
I met a similar question in a forum once, but I can't find it now. So how to solve this problem?
19823[/snapback]
it should just echo back to the shell that you started houdini from.
If you've closed this shell it won't echo anywhere.
Do you mean for a shader? You can get it to print out to a file using render verbose option and specifying a file.
19844[/snapback]
Yes, for a shader or for other VEX stuff like custom COPs. What to do if I want to see output messages in SHOPs preview or in COPs?
