mirHadi Posted June 16, 2017 Share Posted June 16, 2017 (edited) Hello I have a very strange situation where the grain particles suddenly explode along a line!.instead of volume collision I used "use surface collision" for collision detection for the body of the butterfly .as you can see there is no problem, but right the next frame the particles explode in such a strange way that I couldn't figure out why. I checked the setting for dozens of times... I found nothing wrong.I have other simulation with the same setting, It is worse.please let me know If something's wrong. thank you in advance Edited June 16, 2017 by haaranoos Quote Link to comment Share on other sites More sharing options...
vineet Posted June 19, 2017 Share Posted June 19, 2017 you can try to use volume collision by making proxy volume in sop level of that butterfly using vdb....hope so it will work..... Quote Link to comment Share on other sites More sharing options...
