When using the particle fluid surface node, it outputs polygons, and they have a really nice filter method to shape the metaball at the conversion to polygon.
1. Is there a way when using a copy sop and metaball (old school way to make a mesh) to apply this same type of filter to the metaball? Is there some kind of just "filter metaball" node?
2. Can the particle fluid surface node , output a filtered metaball field instead of converting to polygons - In other words, can I NOT convert to polygons, but just filter the metaball mesh and then ill convert it to polygons at a later step using the "convert meta" node
