Mind Thrower Posted July 5, 2017 Share Posted July 5, 2017 Hi! Can't figure out how to assign attribute to different group parts that boolean made. I have a cylinder with some cylinders rotated and transformed like a tree branches. They intersect with main cylinder. After subtracting them from main cylinder "trunk", there are abseams edge group created. How to assign attribute for each loop(I mean all loops has one attribute but with different values for each loop - 1, 2, 3...etc)? Or how can i create separate group for each loop? This is for purpose to scale/transform them from center of loop in foreach, to affect them all at the same time. Quote Link to comment Share on other sites More sharing options...
Mind Thrower Posted July 5, 2017 Author Share Posted July 5, 2017 Made some simple scene with simple setup example. boolean_attrib_groups.hip Quote Link to comment Share on other sites More sharing options...
Houdini7 Posted July 5, 2017 Share Posted July 5, 2017 Why don't you transform your original tubes ? The changes will affect the resulting holes. You can change every tube seperately and the transformation is correct around the center. Quote Link to comment Share on other sites More sharing options...
Mind Thrower Posted July 5, 2017 Author Share Posted July 5, 2017 Hi, Houdini7! Scene with tubes is just an example=) I need to scale separate groups without scaling the tubes connected. Quote Link to comment Share on other sites More sharing options...
Houdini7 Posted July 6, 2017 Share Posted July 6, 2017 You could try with one boolean per tube, so you would have separate abseams groups (you can name them differently). Then you would have one group for each seam. Quote Link to comment Share on other sites More sharing options...
