cracking effect
seifdune
do a shatter geo like in the sidefx tutorial, then pack them based on connectivity
create an object to define places to crack
transfer a custom attribute to the object with a falloff, like f@crack = 1; or sth
create some random normals with attribute randomize
in a vop use displace along normals to move the pieces, so connect the this custom attribute you transfered to displace along normals amount input
that should get you started with a basic setup.
But this is a diamond so you would see the already shattered object even if it was not broken
so right after the shaterring, store their rest attribute
and after the animated object type drop a wrangle and run it for interior faces only
float moved = @rest-@P;
if(moved = 0)
     removepoint(0,@ptnum);
then fuse the whole thing back to together
Edited by tricecold
