Houdini Pyro - Collision resize
michaelb-01
The gasresizefluiddynamic node resizes pretty much all the fields in the simulation, however if you have a collision volume that is moving through the sim you surely don't need that to be the same size as the density field, it just needs to be large enough to contain the collision object. Is there a way to set this up? I tried cracking open the node and removing collision and collisionvel from fields parameter in gasresizefield_smoke, I then created a separate gasresizefluiddynamic for just the collision fields. But for some reason my collision fields are still resizing to be the same size as the density field..
They will until the gas resize node resizes them right? Then they will resize to fit whatever you have in the tracking field (e.g. Density). So I had hoped I could have a separate resize just for the collision and collisionvel which just tracked by the collision field that I'm sourcing, but it doesn't seem to work...
