FLIP Velocity leap
90okm
HI ! i've faced the strange flip behaviour
i have a flip container following some object
and i create some disturbance area by transferring v attribute from points to flip particles.
Nothing more - no collision , no additional forces...
particle reseeding - OFF
everything goes fine for a while, but at some frame the velocity field makes strange boost across all container , as you can see in the attached GIF
what happens there ?
Hey, as this is weird situation - you will likely need to supply file to get solution. Check the v attribute on your points in SOP, if it doesn't reflect the sim then you know its broken Simulation. It looks like a linear increase, are you adding v to v every frame some how?
