multiple target particle morph
benchan
Hi benchan, I think you can change the target mode in popsteerseek to be using points instead of position, and feed in a SOP of the shape you want it to be with scattered points. Also in the second tab you can determine arrival and braking force to make it a full stop instead of swirling around the target points.
