leohak Posted August 8, 2017 Share Posted August 8, 2017 (edited) hello! probably a simple mistake but here I go. I'm trying to recreate the following effect and can't get the rotation from the points to the small objects can you help me? overgrowth.hipnc Edited August 8, 2017 by leohak Quote Link to comment Share on other sites More sharing options...
Matt_K Posted August 8, 2017 Share Posted August 8, 2017 (edited) Hi there, Take a look at this link and the rest of the orientation snippets - it will mean getting into some vex code, but it should give you what you need:http://www.tokeru.com/cgwiki/index.php?title=HoudiniVex#Copies_to_sit_on_a_surface.2C_with_random_rotation.2C_with_orient Hope that helps! Matt. Edited August 8, 2017 by Matt_K correction Quote Link to comment Share on other sites More sharing options...
leohak Posted August 8, 2017 Author Share Posted August 8, 2017 thanks, great resource! @orient is what i was after. now just need to figure out the direction Quote Link to comment Share on other sites More sharing options...
leohak Posted August 8, 2017 Author Share Posted August 8, 2017 (edited) ok it looks like i have the rotation axis right but the orient is not working like i expect any hints? overgrowth_A2.hipnc Edited August 8, 2017 by leohak wrong file Quote Link to comment Share on other sites More sharing options...
leohak Posted August 8, 2017 Author Share Posted August 8, 2017 sorry for that the answer was there with the dihedral function Quote Link to comment Share on other sites More sharing options...
leohak Posted August 13, 2017 Author Share Posted August 13, 2017 If someone will be interested overgrowth_A2.hipnc Quote Link to comment Share on other sites More sharing options...
