Baldric Posted August 10, 2017 Share Posted August 10, 2017 Hello everyone, today I need to try out the wedge rop for the first time. As far as I can tell I have set things up properly, and very similarly to the help file example, but I run into a strange problem. Basically the wedge rop does not randomize the parameters for each wedge differently. I have set up 4 wedges for a tiny particle system example, and although the wedge files look different from the original sim, they all look exactly the same to each other when I read them in with a file sop. If anyone would take a quick look at the provided example file and explain to me what I am doing wrong I would appreciate it very much indeed. Thanks, Doug wedge_node_issue_dkj_v001.hip Quote Link to comment Share on other sites More sharing options...
j00ey Posted August 10, 2017 Share Posted August 10, 2017 I can't see anything set wrongly in your wedge ROP. Did you try turning off caching on your DOP network then running the wedge? Quote Link to comment Share on other sites More sharing options...
Baldric Posted August 10, 2017 Author Share Posted August 10, 2017 Thanks for the reply J00ey, I've tried your suggestion and turned off the caching on the dop network, but it does not improve the situation. Now the first wedge is different to the "original" sim, but the other wedges are now the same as the original. I am really stumped here as to what is going on... Quote Link to comment Share on other sites More sharing options...
j00ey Posted August 10, 2017 Share Posted August 10, 2017 Sorry, I hadn't noticed before but I think you just need to turn on 'Initialise Simulation Ops' on the Geometry ROP. I just tested it and it came out as expected. 1 Quote Link to comment Share on other sites More sharing options...
Baldric Posted August 10, 2017 Author Share Posted August 10, 2017 Thanks J00ey! That seems to work. Will save my weekend! :-) Cheers! Quote Link to comment Share on other sites More sharing options...
3dandvfx Posted August 20, 2017 Share Posted August 20, 2017 Thanks! Quote Link to comment Share on other sites More sharing options...
RobertHodgin Posted September 5, 2017 Share Posted September 5, 2017 Oh jeez, Initialize Simulation Ops checkbox was the reason I lost a 3-day weekend worth of sims and renders. Glad I found this thread. Quote Link to comment Share on other sites More sharing options...
