art3mis Posted August 12, 2017 Share Posted August 12, 2017 (edited) Hi Trying to reproduce this walk thru tutorial on Edge Displacement. At exactly 8:00 in the author lays down a "Surface Model Shader" inside a VOP material. I can't find this although it is clearly in the documentation http://www.sidefx.com/docs/houdini/nodes/vop/surfacemodel ...has it been deprecated in latest build Houdini? I'm running 16.0.687 Edited August 12, 2017 by art3mis Quote Link to comment Share on other sites More sharing options...
art3mis Posted August 12, 2017 Author Share Posted August 12, 2017 Op Ok found the answer. so now Surface Model Shader in the new Material workflow is Classic Shader Core but inside a Material Network>Material Builder node https://www.sidefx.com/forum/topic/48599/ Confused though why Surface Model Shader is still in documentation? 1 Quote Link to comment Share on other sites More sharing options...
