seba00700 Posted August 15, 2017 Share Posted August 15, 2017 Hi, what I want to do, as the title says, is to emit particles from an animated 2d texture. So far what i have acomplished, is to emit particles from a standard, non animated 2d texture, but i cant get it to be animated, i leave the files i have been working on, im sure is just a stupid thing that i have to turn on, but i cant find it.Also if there is an easier way, or anothert way you may think i could acomplish the same effect just say it.Thanks in advanced. test_animated texture.rar Quote Link to comment Share on other sites More sharing options...
mine Posted August 15, 2017 Share Posted August 15, 2017 (edited) Try to promote the texture parameter in the VOP. I think you can't use $F expressions inside a VOP, so you can just promote the parameter and you should be good to go Edited August 15, 2017 by mine 1 Quote Link to comment Share on other sites More sharing options...
seba00700 Posted August 16, 2017 Author Share Posted August 16, 2017 6 hours ago, mine said: Try to promote the texture parameter in the VOP. I think you can't use $F expressions inside a VOP, so you can just promote the parameter and you should be good to go Thanks Man, that worked Quote Link to comment Share on other sites More sharing options...
