heydeun2 Posted August 18, 2017 Share Posted August 18, 2017 (edited) Hi, I'm a student learning houdini. I'm working with particles and I want to delete just few of the points that I choose. I tried to use particle ID but because of the life expectancy variance, the id keeps changing and I couldn't delete the point. So, for the same reason delete SOP doesn't work too. (It only gets deleted in the specific frame which I selected the point) Are there any resolutions of deleting particles that I want to delete? I've also seen an example hip file in odforce that uses 'for loop node' in VOP but I couldn't try that way because it doesn't work in houdini 16. Edited August 18, 2017 by heydeun2 Quote Link to comment Share on other sites More sharing options...
3dome Posted August 18, 2017 Share Posted August 18, 2017 (edited) if you get the particles from a popnet (and on the source "create id" is on, which is default) the IDs do not change when particles die or get created. But the pointnumber (@ptnum) does! so deleting by ID should work just fine. so if you want to delete specific points, note down their ID from the geo spreadsheet and then you can use a blast SOP, put it to points and in group parameter put @id=x @id=y @id=z and so on (replace x y z with the id) Edited August 18, 2017 by 3dome Quote Link to comment Share on other sites More sharing options...
heydeun2 Posted August 18, 2017 Author Share Posted August 18, 2017 Thanks for the advice. I'll have a try Quote Link to comment Share on other sites More sharing options...
