whats the correct way to asign Cd to an array?
i have this in a wrangle,  and i want to asign the Cd value only to the points returned by the point cloud,  what is the correct way to do it?  i have this atm,  but whats then the apropiate syntaxis to do it?
edit:  setpointattrib doesnt work in this case i dont know why...  it just assign Cd to everything
int hnd = pcopen(0, "P", @P, 1, 3);
int sourceGoals[];
int valor[];
vector valorcd = {1,0,0};
while(pciterate(hnd)){
        int sourceGoal;
        pcimport(hnd,"Pnum",sourceGoal);
        push(valor,sourceGoal);
        push(sourceGoals,sourceGoal);
    foreach (int i; valor){
            @Cd = valorcd;
 i[]@ptvalor = valor;
Edited by dyei nightmare
Use pcfind and a foreach? So something like:
//Set color to black
@Cd = 0;
// Pc find
float radius = ch("radius");
int maxpoints = ch("max_points");
int pointcloud[] = pcfind(1, "P", @P, radius, maxpoints);
foreach( int point ; pointcloud){
    @Cd = {0,1,0} ;
I think that's what you were looking for...
pcfind_example.hiplc
From my understanding the Pc find is a convenient way to iterate over a point cloud; it returns an array of the points and then, typically, you run those points through a foreach. This is roughly equivalent to doing a pc open and using a while loop to iterate over the points. Which makes your code/vop network much shorter and cleaner :)
Also it takes point groups / expressions. E.g.:
// Set Cd
@Cd=0;
// pcfind
// Mask string
string mask = "@P[0]>0.5";
int pointcloud[] = pcfind(1, mask, "P",  @P, radius, maxpoints);
    @Cd = {0,1,0} ;
Will only look at the points whose x position is greater than 0.5
pcfind_mask.hiplc
  • Like 2
  • 1 month later...
