BOILING | Constraining POP particles birth position to deforming mesh
Hello there,
I am learning Houdini and I tried to apply the GeoBoil setup to a dancing humanoid.
I am struggling to understand how to use attributes to constrain particles to their birth position on the moving mesh.
I have read plenty of related topics, but I honestly can't come close to any solution.
I tried freezing the mesh with time-shift, scattering points, using scattered points to generate particles in the POPnet and then restoring the animation, but of course the particles remain in the position they were generated and do not stick to the surface.
I attached the basic setup file and  the .abc I used.
Thanks in advance!
boil.hip
On 8/25/2017 at 11:51 PM, vtrvtr said:
Here's a different take on it. It seems like a nice case to use a custom solver
odf_boiliong.hipnc
I understood how the attribute interpolate node works! Thanks.
But still I can't implement it in my setup... #n00b
update: .hip attached
boil_stick-particles_GETTING_SOMEWHERE.hip
Edited by neurostudio
