Poly's UV to VDB transfer edge problem
majinpu
Hi guys!
I have recently done a model of a procedural tank. I noticed that sometimes I get some bad faces on my geo due to the complexity of the model, so for a procedural texturing workflow I have just discovered that I can transfer my uv's to vdb volumes.
In the file I have uploaded I am just using a cube with a bevel, but when I transfer the uv's on the hi poly converted volume I got some errors on seams... How can I fix this?
Also, If you can give me any infos or suggestion about a smart workflow to keep in mind when doing some hard surface modelling keeping the structure procedurally right for uv's and texture? I have always when it comes to subdivide some pieces of geometry! I had a look around but I am a little bit confused...!!
Thank you!
vdb_uvs.hipncvdb_uvs.hipnc
vdb_uvs.hipnc
