Guest tar Posted August 27, 2017 Share Posted August 27, 2017 (edited) does the Visualizer work for packed things? Want to show the name attribute, which after packing is only visible in the viewport widget and the geometry spreadsheet, but not in a Visualizer. NameAttribute.hiplc Edited August 27, 2017 by tar Quote Link to comment Share on other sites More sharing options...
Dam Posted August 28, 2017 Share Posted August 28, 2017 (edited) Hi Marty, For some obscure reason doesn't work if the name attribute it's on primitive, I've promoted it to points and now I'm able to visualize the tex on viewport Cheers NameAttributeVizToPoints.hipnc Edited August 29, 2017 by Dam Quote Link to comment Share on other sites More sharing options...
Guest tar Posted August 28, 2017 Share Posted August 28, 2017 hmmm - that's not working here - can you post a screen shot and the vid card driver specs. Might be a bug on LInux. Quote Link to comment Share on other sites More sharing options...
Dam Posted August 29, 2017 Share Posted August 29, 2017 my bad - I've attached the wrong hip before, updated now. can be a viewport issue, on Linux happen a lot NVIDIA GeForce GT 750M 2048 MB Quote Link to comment Share on other sites More sharing options...
Guest tar Posted August 29, 2017 Share Posted August 29, 2017 that addSOP is unpacked. that's why that's working. Cheers Quote Link to comment Share on other sites More sharing options...
Noobini Posted August 29, 2017 Share Posted August 29, 2017 doesn't that defeat the purpose tho ? since you asked how can I get this to work with PACKED things in the first place... (and I don't think you even need the promo...disable it, still works) Quote Link to comment Share on other sites More sharing options...
Guest tar Posted August 29, 2017 Share Posted August 29, 2017 (edited) yes - sorry if that isn't clear - I want to display a packed attribute via a visualiser. Edited August 29, 2017 by tar Quote Link to comment Share on other sites More sharing options...
Noobini Posted August 29, 2017 Share Posted August 29, 2017 I find it odd that if I press W (using the orig file with no mods)...and tumble around...I get flickering of some 'numbers' which might be internal representations of the 'piece whatever' Quote Link to comment Share on other sites More sharing options...
Dam Posted August 31, 2017 Share Posted August 31, 2017 uhh Interesting, working for me as well now, good catch @Noobini - cheers Quote Link to comment Share on other sites More sharing options...
