spaceboyzero Posted August 14, 2005 Share Posted August 14, 2005 hi all... i have a character rig set up as an otl and i have a walk cycle, i`m trying to use chops to grab the cycle from my character, and then export it to a dupllicate of the otl, i am going to have a number of these so need to offset the cycle etc.. so far i have tried. Fetch (all channels) from otl 1 > export (all channels) to otl2 this sends the destination otl off somewhere and mashes him up! also tried using a rename chop to do the exporting, had it working at one point, butr now i cant seem to do it again!! i had in the fetch ( where obj 1 and 2 are the equivalents of my identical otl`s) node > /obj/geo1 channels > * and in the rename from > /obj/geo1 to > /obj/geo2 iany help appereciated.. cheers, Mark Quote Link to comment Share on other sites More sharing options...
edward Posted August 15, 2005 Share Posted August 15, 2005 I don't see why it won't work if you have identical otls as it will just do parameter name matching. Have you tried a simple case to make sure you understand how its supposed to fix together? Quote Link to comment Share on other sites More sharing options...
