seifdune Posted August 29, 2017 Share Posted August 29, 2017 how to add motion path in view port during animation in houdini, motion path allow animator to edit the animation curve direct in the view port. Quote Link to comment Share on other sites More sharing options...
djiki Posted November 25, 2017 Share Posted November 25, 2017 Basically, you can do that only if path object exists in your scene and some object motion is constrained to follow that path. Simple keyed translation values can not be visible in viewport as editable path. In an advanced approach, it would be possible to proceduraly generate some 3D curve in scene from keys you entered in transformation tab. Then such curve would be editable in viewport as any other curve. After edit is completed it would be possible to reapply those modifications into source channels as offsets for correction .... but I'm sure you don't need that Quote Link to comment Share on other sites More sharing options...
Guest tar Posted November 25, 2017 Share Posted November 25, 2017 Excellent viewport editable motion paths was added in 16.5. Turn on motion path on the Pose Tool. Quote Link to comment Share on other sites More sharing options...
