Javier31 Posted September 1, 2017 Share Posted September 1, 2017 hi there, I am trying to search for the closest points with different id and then connect them :-) Basically, every single point should be able to connect with other 2 or 3 other points max but avoiding points with same id (so no connections with the points of the same curve) see attached file and screenshot of what i got so far many thanks!! :-) connecting just to other lines.hipnc Quote Link to comment Share on other sites More sharing options...
Dam Posted September 2, 2017 Share Posted September 2, 2017 (edited) Hi @Javier, Here some idea how avoid the same @id and connect points with different @id using point clouds, I belive there are many other ways, this is just a quick one, Cheers! Dam float radius = chf('radius'); int maxpoints = chi('searchpoints'); int near_ptnum; int new_prim; int handle = pcopen(0,"P", @P, radius, maxpoints); while(pciterate(handle)) { int cur_id; pcimport(handle, "id", cur_id); if(i@id != cur_id) { pcimport(handle, "point.number", near_ptnum); new_prim = addprim(0,"polyline"); addvertex(0,new_prim,@ptnum); addvertex(0,new_prim,near_ptnum); } } pcclose(handle); connecting_just_to_other_lines.hipnc Edited September 3, 2017 by Dam 1 Quote Link to comment Share on other sites More sharing options...
Thomas Helzle Posted September 2, 2017 Share Posted September 2, 2017 (edited) I wondered the same thing recently and wrestled with the "group" parameter in nearpoints, but somehow did not grok how to write a group expression that does this. Using pcopen feels much clearer there, although one will probably still have to have a large maxpoints number to be sure to hit something on the other curves and then maybe limit the result manually in the while loop. I was searching for only one closest point on any curve different from the current, using the "class" attribute from the connectivity node... Cheers! Tom Edited September 2, 2017 by Thomas Helzle Quote Link to comment Share on other sites More sharing options...
Dam Posted September 3, 2017 Share Posted September 3, 2017 (edited) Yeah pcopen needs a bit of adjustments on the radius at first place. for limiting the number of connections to 3 or less I found helpfull "pcnumfound" function, It returns the number of points founded and with this information stored in an attribute can be possible trigger the connections. So even we found more than 10 points, we can filter from those only the three avaible for make connections, but for a more accurate selection I guess with an array of "nearpoint" will be easier taking the first 3 or less found points with a specific order int handle = pcopen(0,"P", @P, radius, maxpoints); while(pciterate(handle)) { int cur_id; pcimport(handle, "id", cur_id); if(i@id != cur_id) { pcimport(handle, "point.number", @near_ptnum); i@pt_found = pcnumfound(handle); if(@pt_found < 3){ new_prim = addprim(0,"polyline"); addvertex(0,new_prim,@ptnum); addvertex(0,new_prim,@near_ptnum); } } Edited September 3, 2017 by Dam Quote Link to comment Share on other sites More sharing options...
Thomas Helzle Posted September 3, 2017 Share Posted September 3, 2017 I ended up using this (with "@class" being the per-object attribute from the connectivity node): float searchrad = chf("Searchradius"); int maxpts = chi("MaxPoints"); int nearpnts[] = nearpoints(0, @P, searchrad, maxpts); int maxlines = chi('MaxLines'); int cnt = 0; foreach(int pnt; nearpnts){ if(@class != pointattrib(0, 'class', pnt, 1)) { if (cnt >= maxlines) { break; } int line = addprim(0, "polyline"); addvertex(0, line, @ptnum); addvertex(0, line, pnt); cnt += 1; } } While this works fine, I still wonder if it wouldn't be faster to have a fitting group expression directly in nearpoints... ? Cheers, Tom Quote Link to comment Share on other sites More sharing options...
Dam Posted September 3, 2017 Share Posted September 3, 2017 (edited) This is cool For the group stuff, should be something like this: @group_pts = int(@P.y % 2); @Cd.x = @group_pts; //vizGroup int maxpts = chi("MaxPoints"); int nearpnts[] = nearpoints(0, @P, @group_pts, maxpts); int maxlines = chi('MaxLines'); int cnt = 0; foreach(int pnt; nearpnts){ if(@class != pointattrib(0, 'class', pnt, 1)){ if (cnt >= maxlines){ break; } int line = addprim(0, "polyline"); addvertex(0, line, @ptnum); addvertex(0, line, pnt); cnt += 1; } } In this way only the points in the @group_pts will serch for the nearest. In a case were every point it's searched within the radius but we ask for the @group_pts before to make connection: @group_pts = int(@P.y % 2); @Cd.x = @group_pts; //vizGroup float searchrad = chf("Searchradius"); int maxpts = chi("MaxPoints"); int nearpnts[] = nearpoints(0, @P, searchrad, maxpts); int maxlines = chi('MaxLines'); int cnt = 0; foreach(int pnt; nearpnts){ if(@class != pointattrib(0, 'class', pnt, 1)) { if (cnt >= maxlines || @group_pts == 1) { break; } int line = addprim(0, "polyline"); addvertex(0, line, @ptnum); addvertex(0, line, pnt); cnt += 1; } } Cheers - Dam group_expression_near_points.hipnc Edited September 3, 2017 by Dam 1 Quote Link to comment Share on other sites More sharing options...
