Multiple UVsets on same geometry / or multiple UV scales
I have a layered shader, where say the material inputs have a UV scale of x20 for example, and the masks between the different layers have a UV scale of x1.
In Maya, you would simply adjust that on the UV node attached to the texture maps.
How do I do this in Houdini?
Alright. I think I have figured out a solution:
Using the layer node allows you to add UV sets to a geometry, that you later than pull in using the shading layer parameter node. This should work not just for UVs but also for colours and alpha channel values.
