florian_DKS Posted October 23, 2020 Share Posted October 23, 2020 On 09/05/2019 at 12:40 PM, Thomas Helzle said: I recently looked into it again and found a workaround that works for my uses: I render a Z-Depth AOV set to mimimal distance with my image. This allows to pick the Z-Depth in the Redshift viewers sidebar. I then enter the value by hand in the camera. Still hoping for a direct option at one point though. The other things I looked at either didn't update at all without a manual refresh or triggered a full scene reload. Maybe we should bug Juanjo once more... :-) Cheers, Tom Hey man, i thought this would have been solved ages ago, in redshift, you need to put the expression like below, and remember to uncheck "use houdini camera focus/fstop"! Hope this helps and that i did not misunderstand the issue ! Quote Link to comment Share on other sites More sharing options...
Thomas Helzle Posted October 23, 2020 Share Posted October 23, 2020 That was the old workaround, needing an object (probably my own screenshot even ;-) ), but in more recent versions of Redshift you can indeed click into the IPR to set the focus point. Doesn't work well with fiddly thin strands, but is great for product shots etc. Cheers, Tom Quote Link to comment Share on other sites More sharing options...
