U coordinate on closed prim
konstantin magnus
How can I read the U coordinate (from 0 to 1) of closed primitives in VEX?
I tried xyzdist and primuv ...
int prim;
vector uv;
xyzdist(0, @P, prim, uv);
v@uv_profile = set(uv.x, 0, 0);
... but I only got results that did not represent the relative distance between the vertices.
Edited by konstantin magnus
Added sketch
No worries, I tried to have go at it in VEX, but I'm not entirely sure if the results are correct or accurate.
In the attached file, as it turns out, the initial SOPs method (in red) I suggested does seem to appear incorrect when laid out as a straight line. The VEX method (in green) seems to visually appear more correct.
Compare the points 4 to 8..
If I turn off the Closed toggle of the Curve SOP, the RED line will match the GREEN line.
Have a look at the setup, and see if it anywhere near the direction you wanted.
u_coord2.hiplc - H16.0.689 Indie
My head is kinda twirling at the moment, I may need to sleep this through for now :))
Cheers!
Jeff
  • Like 2
@galagast, thanks! I updated my own snippet with closure check to work like yours.
Here is what I got:
// Detail wrangle.
float length = primintrinsic(0, "measuredperimeter", 0);
// Set to false if value of 1.0 is unwanted for the last point
// of closed prims and instead need to be treated as if point with
// u=1 is coincident with the first point (like in unrolled prims).
int as_open = true;
// Compensate for closing auto-edge length.
if (as_open && primintrinsic(0, "closed", 0))
    vector auto_edge = point(0, "P", 0) - point(0, "P", @numpt-1);
    length -= length(auto_edge);
// Compute curve u.
float passed = 0;
for (int i = 1; i < @numpt; i++)
    vector d = point(0, "P", i) - point(0, "P", i-1);
    passed += length(d);
    setpointattrib(0, "u", i, passed/length);
Difference between behaviors "as open" and "as unrolled":
  • Like 2
  • Thanks 1
I think primuvconvert function will be helpful for intrinsic uv attribute.
An example of code to get relative distance between the vertices.
// Run Over -> Points
int prim;
vector uv;
int mode = 4; // PRIMUV_UNIT_TO_UNITLEN
u@uv_profile = primuvconvert(@OpInput1, set(uv.x, 0.0), prim, mode);
Edited by satoru
  • Like 3
