Polywire changing point count on deformation
scorpes
If I put a bend deformer on a simple L-system, the poly count will change if I put a polywire at the end. This is a problem for me, any way to fix this problem? I know that I can turn on tubes on the lsystem but I'm using a wiresolver in my case.
polywire_changingPointNumbers.hipnc
Edited by scorpes
because of the Smooth Point = 1 in Polywire.
If you have Smooth Point = 0, it works fine...geo not changing...coz it's not 'smoothing' but the segments are disjointed...ie. next to useless to you.
So add a Resample after the Transform...Bob's your uncle....
Edited by Noobini
