no new menus after fresh install
Follyx
Had to install a fresh version of my Houdini 16.0.633. No matter what I'm installing, I miss the new menus. I.e. Redshift and arnold. I didnt touch the *.env file and nothing else. The arnold variables inserted proper during install. as well the redshift entrys are correct. I dont get menus nor the plugin itself. Nothing nada. Every path is correct. For sure.
Do you have a solution for this problem?
I would check if the plugin version is too old for new Houdini. In houdini.env file add:
HOUDINI_DSO_ERROR = 1
In case some plugin is too old, you will get startup error like this:
Houdini DSO Error
(127) Couldn't load some_plugin_name.dll.
This is probably because this file was intended for use with a different version of Houdini.
OK
