bonassus Posted September 20, 2017 Share Posted September 20, 2017 I'm trying to set up two pig heads in a grain sim that collide together. an extension of the grainular solid example in Jeff Lait's h15 grains masterclass. in stead of one pig head i want to wire in two. I've set up two pig heads (skipping the bone group part for now) see attached file. Jeff shows how to override the P and v with from an animated version of the geo with a wragle. I've set the dop net up the same way with two sources. however for some reason one of the P values apparently collapses to 0. if i switch the merge order it switches which source goes to 0. see attached file. I'm obviously missing something here. help would be appreciated. twosolidpigs.hiplc Quote Link to comment Share on other sites More sharing options...
