two objects in a granular solid sim
bonassus
I'm trying to set up two pig heads in a grain sim that collide together. an extension of the grainular solid example in Jeff Lait's h15 grains masterclass. in stead of one pig head i want to wire in two. I've set up two pig heads (skipping the bone group part for now) see attached file. Jeff shows how to override the P and v with from an animated version of the geo with a wragle. I've set the dop net up the same way with two sources. however for some reason one of the P values apparently collapses to 0. if i switch the merge order it switches which source goes to 0. see attached file. I'm obviously missing something here.
help would be appreciated.
twosolidpigs.hiplc
