coss Posted September 26, 2017 Share Posted September 26, 2017 Hello guys a basic question for a simple problem... that im sure has a simple answer. Want to spring-constraint pieces of packed rdb objects (debris) to be driven by a group of animated points. Right now im keeping it simple just a one-to-one connection. Something similar to this: Sadly his test scene is not using packed objects Attached is the test scene i 've been using For some reason i havent got the answer and right now i am just going in circles Thanks for the help glue_cns_test.hipnc Quote Link to comment Share on other sites More sharing options...
mestela Posted September 26, 2017 Share Posted September 26, 2017 This might help: http://www.tokeru.com/cgwiki/index.php?title=ConstraintNetworks Basically your constraint points didn't match the names of the packed objects, so no constraints were made. I tweaked your setup so that the constraints polylines are made directly from the packed geo, so everything matches up. me_glue_cns_test.hipncFetching info... 2 Quote Link to comment Share on other sites More sharing options...
coss Posted September 26, 2017 Author Share Posted September 26, 2017 Hey mestela Thanks a lot for the help! now it much more clear Don't know why i never stumbled upon that link... Quote Link to comment Share on other sites More sharing options...
