Can't match an OBJ and a MDD outside Houdini. Was the OBJ exported changed or user error?
probiner
I tried to match a MDD and an OBJ exported from Houdini in several apps, but always failing. Here in Blender, on the left, the OBJ. On the right, a correct match of what I see in Houdini, exported with another format.
OBJ was exported with Right-Click > Save > Geometry > OBJ
MDD was exported with ROP MDD Point Cache.
Scene file used attached.
Let me know if you see the same. If so I guess I'll file a RFE.
Cheers
PRB_MDD_Export_Test_01.hipnc
Edited by probiner
@f1480187
Thank you for looking into it. What's the problem with spheres? :) I did have another more complex object, so I tried to isolate the problem this way,
PLY is what I used on the working sphere. thanks for the flipping heads up!
Another thing that worked, was using https://github.com/heimlich1024/OD_CopyPasteExternal
Cheers
I tried your test file and it worked fine for me in Blender 2.78c.
The only thing I may have done differently is that I dropped down a ROP Driver at the end of the sphere and kicked out the original .obj from that node instead of using any File/Export options.
Edited by Atom
