Deleting Pieces of Geometry Vex
evanrudefx
Hey!!!
I am trying to add smoke to a shattered statue simulation. The falling pieces will emit smoke. I want the geometry to be deleted until the pieces reaches a certain velocity (if (@v.y < ch('threshold'));) , so that the emitter geo wont appear until the geometry is actually moving. That will keep smoke from emitting while the statue isn't falling apart. Finally,  I need the geometry to be deleted when it is about to hit the ground, so I guess delete by Y position. I am trying to do this in an attribute wrangle. All the pieces have their own name attribute, piece1, piece2, etc. Here is my logic so far, I just don't know how to right it in vex:
if (@v.y < ch('thresholdvelocity')) or (@p.y < ch('thresholdposition') then delete that whole piece.
Any help would be appreciated. I am new to vex and I am trying to learn these things on my own, but sometimes I need help : )
Thanks
edit: I can't add my original scene, but I made a sample scene.
delete_geo.hipnc
Hi Van, I attached a file below that I tweaked a little bit, not sure if this is what you mean, but basically removepoint() / removeprim() is convenient for deleting geo in a wrangle node, you can search in the vex functions or type in this and hit F1 in the textport in wrangle node to view the documentation :D
I bypassed the unpack for now, so they are packed geo and can be manipulated at point level, but if you need them to be unpacked geo, you can add "v" at the transfer attribute input textfield in the unpack node to get the velocity from the packed sim geo. Hope this helps.
delete_geo_vl.hipnc
  • Thanks 1
this is how I was originally doing it, but I found out the problem was with my velocity channel so it was deleting some faces rather than individual chunks. I'll keep this thread updated.
edit: I thought this method didn't work because it was deleted faces rather than individual chunks. That was because my velocity channel was "messed" up.
Edited by ejr32123
Here is what I am doing now:
if (@P.y < ch('pthreshold')
    || abs(@v.y) < ch('vthreshold'))
    removepoint(0,@ptnum);
having v.y < "whatever"  doesn't work in my case because the pieces have negative velocity. So I get the abs of the @v.y. This seems to be working!!!
Edited by ejr32123
Hi, I looked into your sample file, hopefully the attached hip file is something close to what you were after.
Basically, you would need to use length(@v) to get the speed, and not use @v.y
You could also remap that to a value or color (for visualization), then use that to control the smoke emission strength.
Houdini 16.0.731 Apprentice - delete_geo_v2.zip
