ISUther Posted September 29, 2017 Share Posted September 29, 2017 (edited) 00:00:00 689MB WARNING | [htoa.colorspace] Render color space "" does not exists in color manager, using default "linear" instead. 00:00:00 689MB WARNING | [htoa.colorspace] Auto color space "" does not exists in color manager, using default "sRGB" instead. 00:00:01 883MB ERROR | [void __cdecl htoa::arnold::Node::pullParameter] parameter not found: transform_type (ar_transform_type) 00:00:01 800MB ERROR | [htoa.material] Cannot find parent SHOP for shader path /mat/principledshader1 Anyone knows how to fix this. Also i seem to have ARNOLD watermark but licence server seems to be running What i did was start my project. Loaded in OBJ file and it is now as (geo file) i went to "Out" section >> Created "Arnold" node >> Created camera In "Out" section i selected "Arnold" node and clicked "Render to Disc" Then i get instantly an errors: 00:00:00 158MB | [vop_shaders] Registering shaders ... 00:00:00 158MB | loading plugins from C:/Users/Tann/htoa/htoa-2.1.3_rcca6014_houdini-16.0.705/htoa-2.1.3_rcca6014_houdini-16.0.705/arnold/plugins ... 00:00:00 159MB | htoa_mandelbulb_proc.dll: mandelbulb uses Arnold 5.0.1.3 00:00:00 159MB | loaded 1 plugins from 1 lib(s) in 0:00.00 00:00:00 159MB | [vop_shaders] Loading metadata file: C:/Users/Tann/htoa/htoa-2.1.3_rcca6014_houdini-16.0.705/htoa-2.1.3_rcca6014_houdini-16.0.705/arnold/metadata/cameras.mtd 00:00:00 159MB | [vop_shaders] Loading metadata file: C:/Users/Tann/htoa/htoa-2.1.3_rcca6014_houdini-16.0.705/htoa-2.1.3_rcca6014_houdini-16.0.705/arnold/metadata/lights.mtd 00:00:00 159MB | [vop_shaders] Loading metadata file: C:/Users/Tann/htoa/htoa-2.1.3_rcca6014_houdini-16.0.705/htoa-2.1.3_rcca6014_houdini-16.0.705/arnold/metadata/options.mtd 00:00:00 159MB | [vop_shaders] Loading metadata file: C:/Users/Tann/htoa/htoa-2.1.3_rcca6014_houdini-16.0.705/htoa-2.1.3_rcca6014_houdini-16.0.705/arnold/metadata/shaders.mtd 00:00:00 160MB | [vop_shaders] Loading metadata file: C:/Users/Tann/htoa/htoa-2.1.3_rcca6014_houdini-16.0.705/htoa-2.1.3_rcca6014_houdini-16.0.705/arnold/metadata/shapes.mtd 00:00:00 162MB | [vop_shaders] shader registration done. 00:00:00 162MB | 00:00:00 162MB | releasing resources 00:00:00 162MB | Arnold shutdown 00:00:00 689MB WARNING | [htoa.colorspace] Render color space "" does not exists in color manager, using default "linear" instead. 00:00:00 689MB WARNING | [htoa.colorspace] Auto color space "" does not exists in color manager, using default "sRGB" instead. 00:00:01 883MB ERROR | [void __cdecl htoa::arnold::Node::pullParameter] parameter not found: transform_type (ar_transform_type) 00:00:01 800MB ERROR | [htoa.material] Cannot find parent SHOP for shader path /mat/principledshader1 00:00:00 636MB WARNING | [htoa.colorspace] Render color space "" does not exists in color manager, using default "linear" instead. 00:00:00 636MB WARNING | [htoa.colorspace] Auto color space "" does not exists in color manager, using default "sRGB" instead. 00:00:01 799MB ERROR | [void __cdecl htoa::arnold::Node::pullParameter] parameter not found: transform_type (ar_transform_type) 00:00:01 774MB ERROR | [htoa.material] Cannot find parent SHOP for shader path /mat/principledshader1 Also When i create a Arnold Network dive inside and create arnodl standard surface and click on output node i get an error. 00:00:00 158MB | [vop_shaders] Registering shaders ... 00:00:00 158MB | loading plugins from C:/Users/Tann/htoa/htoa-2.1.3_rcca6014_houdini-16.0.705/htoa-2.1.3_rcca6014_houdini-16.0.705/arnold/plugins ... 00:00:00 159MB | htoa_mandelbulb_proc.dll: mandelbulb uses Arnold 5.0.1.3 00:00:00 159MB | loaded 1 plugins from 1 lib(s) in 0:00.00 00:00:00 159MB | [vop_shaders] Loading metadata file: C:/Users/Tann/htoa/htoa-2.1.3_rcca6014_houdini-16.0.705/htoa-2.1.3_rcca6014_houdini-16.0.705/arnold/metadata/cameras.mtd 00:00:00 159MB | [vop_shaders] Loading metadata file: C:/Users/Tann/htoa/htoa-2.1.3_rcca6014_houdini-16.0.705/htoa-2.1.3_rcca6014_houdini-16.0.705/arnold/metadata/lights.mtd 00:00:00 159MB | [vop_shaders] Loading metadata file: C:/Users/Tann/htoa/htoa-2.1.3_rcca6014_houdini-16.0.705/htoa-2.1.3_rcca6014_houdini-16.0.705/arnold/metadata/options.mtd 00:00:00 159MB | [vop_shaders] Loading metadata file: C:/Users/Tann/htoa/htoa-2.1.3_rcca6014_houdini-16.0.705/htoa-2.1.3_rcca6014_houdini-16.0.705/arnold/metadata/shaders.mtd 00:00:00 160MB | [vop_shaders] Loading metadata file: C:/Users/Tann/htoa/htoa-2.1.3_rcca6014_houdini-16.0.705/htoa-2.1.3_rcca6014_houdini-16.0.705/arnold/metadata/shapes.mtd 00:00:00 162MB | [vop_shaders] shader registration done. 00:00:00 162MB | 00:00:00 162MB | releasing resources 00:00:00 162MB | Arnold shutdown 00:00:00 689MB WARNING | [htoa.colorspace] Render color space "" does not exists in color manager, using default "linear" instead. 00:00:00 689MB WARNING | [htoa.colorspace] Auto color space "" does not exists in color manager, using default "sRGB" instead. 00:00:01 883MB ERROR | [void __cdecl htoa::arnold::Node::pullParameter] parameter not found: transform_type (ar_transform_type) 00:00:01 800MB ERROR | [htoa.material] Cannot find parent SHOP for shader path /mat/principledshader1 00:00:00 636MB WARNING | [htoa.colorspace] Render color space "" does not exists in color manager, using default "linear" instead. 00:00:00 636MB WARNING | [htoa.colorspace] Auto color space "" does not exists in color manager, using default "sRGB" instead. 00:00:01 799MB ERROR | [void __cdecl htoa::arnold::Node::pullParameter] parameter not found: transform_type (ar_transform_type) 00:00:01 774MB ERROR | [htoa.material] Cannot find parent SHOP for shader path /mat/principledshader1 Qt Warn: External WM_DESTROY received for QWidgetWindow(0x2cee0a60760, name="RE_WindowWindow") , parent: QWindow(0x0) , transient parent: QWindow(0x0) Qt Warn: External WM_DESTROY received for QWidgetWindow(0x2cea4b82020, name="RE_WindowWindow") , parent: QWindow(0x0) , transient parent: QWindow(0x0) Edited September 29, 2017 by ISUther Quote Link to comment Share on other sites More sharing options...
davpe Posted October 9, 2017 Share Posted October 9, 2017 hard to say whats the problem without seeing the scene. anyway it looks like you're mixing arnold and mantra nodes together. raised errors complaining about principled shader suggest that. also, lights in your scene seems to be mantra lights. those obviously can't be rendered in arnold Quote Link to comment Share on other sites More sharing options...
