jhcl21 Posted October 10, 2017 Share Posted October 10, 2017 I studying about the attribute copy SOP. And had strange behavior. I used the two grids one is Raw:200,Columns:200 and other is Raw100,Columns:100. The result is repeating 4times on Raw instead of 2times. Why not 2times x 2times? I know if i set the grid to 200 x 100, or attribute transfer can solve it but I want to know about the reason, not a solution. Quote Link to comment Share on other sites More sharing options...
Nache Posted October 10, 2017 Share Posted October 10, 2017 Hi Junji, you should take a close look at what's going on when you copy attribute from grid1 to grid2. In fact you're copying the color of each point, number by number (color ptnum 0 -> color ptnum 0) and when you reach point number 10 001 which you haven't in grid1 it begin at 0 again (color ptnum 0 -> color ptnum 10 001). The 2 grids have a different topology so you get different mapping. In your case you're getting kinda the same image because is 100 x 100 and 100*2 x 100*2. If you change your grid2 to 201x201 you'll probably notice that every thing is a bit messed up, that's why. I don't know if i'm clear enough, you can try your setup with 2x2 and 4x4 grids and display points number, that way you'll see what's going on. Gab. Quote Link to comment Share on other sites More sharing options...
jhcl21 Posted October 11, 2017 Author Share Posted October 11, 2017 Hi Gabriel Thank you for your help. That is exactly i was looking for. I understand it now. 1 Quote Link to comment Share on other sites More sharing options...
