probiner Posted October 26, 2017 Share Posted October 26, 2017 I'm using Skin because Sweep output doesn't respond well to multiple profiles and in Skin there's options to deal with it. But I've noticed that Skin doesn't respond well to multiple paths unlike Sweep's output. My question is; while I was able to tackle this with a For Each block running on the paths prims, is there a better way to do it that I might be missing? Scene file attached. SkinTwoPathsTwoProfiles.hiplc Quote Link to comment Share on other sites More sharing options...
Noobini Posted October 26, 2017 Share Posted October 26, 2017 for the Sweep, with Multi profiles...have you tried 'One Primitive At A Time'...in Cycle Type ? Quote Link to comment Share on other sites More sharing options...
probiner Posted October 27, 2017 Author Share Posted October 27, 2017 (edited) Thanks Noobini. I did miss the option in the Sweep SOP: "Cycle type", which will help when there's more than one profile. Another reason I am using Skin over Sweep is also to make a compilable alternative of Sweep that creates caps . So I'm reconstructing the operation. Cheers Edited October 27, 2017 by probiner Quote Link to comment Share on other sites More sharing options...
probiner Posted November 3, 2017 Author Share Posted November 3, 2017 (edited) I'll try to generate paths from the profiles that might help Cheers Edited November 3, 2017 by probiner Quote Link to comment Share on other sites More sharing options...
