天城守卫 Posted October 28, 2017 Share Posted October 28, 2017 (edited) I use sweep sop to convert a line to tube,but the normal just facing inside. if i use polywire ,the normal facing outward. If i just reverse the normal with "@N*=-1",the scene view has display issue,and can't render correct. I do'not know why.... sweep normal.hip Edited October 29, 2017 by 天城守卫 Quote Link to comment Share on other sites More sharing options...
Noobini Posted October 28, 2017 Share Posted October 28, 2017 don't think you can blame Sweep...it's the circle.....or the way the cross section was created. Start a new scene, manually draw a curve, make sure it loops back to form a closed loop: - if you go clockwise, the prim normal points one way - if you go anti-clockwise, the prim normal points the other way So if you want to prove it's NOT the Sweep's fault, go back and Reverse the circle and there's your proof... (this is the same as other 3D s/w, the polygon normal is dependent on the direction of the verts/points that make up the polygon) Quote Link to comment Share on other sites More sharing options...
天城守卫 Posted October 29, 2017 Author Share Posted October 29, 2017 8 hours ago, Noobini said: don't think you can blame Sweep...it's the circle.....or the way the cross section was created. Start a new scene, manually draw a curve, make sure it loops back to form a closed loop: - if you go clockwise, the prim normal points one way - if you go anti-clockwise, the prim normal points the other way So if you want to prove it's NOT the Sweep's fault, go back and Reverse the circle and there's your proof... (this is the same as other 3D s/w, the polygon normal is dependent on the direction of the verts/points that make up the polygon) Thank you so much! I use sort sop to reverse the ptnum ,then i use setprimvertex sop reverse the vertexnum,the normal is perfect. Quote Link to comment Share on other sites More sharing options...
