ISUther Posted November 5, 2017 Share Posted November 5, 2017 Hello, I downloaded demo version of Octane. Installed stand alone version and now trying to install plugin. According to documentation they have: Installing Octane for Houdini The release archive contains everything you need to run OctaneRender™ for Houdini, including the Octane libraries, the plugin binaries, the menu shelf, HDAs, etc.. Compatible Houdini products The OctaneRender™ for Houdini build must match exactly your Houdini install to avoid problems. The OctaneRender™ for Houdini plugin requires Houdini Indie, Houdini FX or Houdini Education. While running in Houdini Indie, the plugin will limit the sequence rendering resolution to 1080p, and the scene export and cloud features will be disabled. Houdini Apprentice cannot run the Octane plugin as they lack support for third party renderers. Plugin Installation To install OctaneRender™ for Houdini, decompress the archive downloaded from the OctaneRender™ website and copy the resulting uncompressed files somewhere. Insert the OctaneRender™ plugin folder path to the houdini.env file. This file is created by Houdini after your first run. The location of this file vary per platform: Linux: ~/houdini15.5/ Windows: C:Documents and Settings<username>My Documentshoudini15.5 Mac OSX: ~/Library/Preferences/houdini/15.5/ On Linux and Mac OSX, append a single line to enable OctaneRender™ for the user: HOUDINI_PATH = /path/to/octane;& On Windows, you need to set the PATH to point to the scripts/bin as well: PATH = "C:/path/to/octane/bin;$PATH"HOUDINI_PATH = "C:/path/to/octane;&" You have to use forward slashes (“/”) on Windows instead of backslashes as path separators. And here is the question: My houdini is installed in path: C:\Users\Tann\Documents\houdini16.0 I placed the plugin i downloaded and extracted to this folder: C:\Users\Tann\Documents\Octane plugin\Octane_3.06.4.0_Houdini_16.0.633_demo_Win64 I have mine set like this. (the .env file) but it does not work. Quote Link to comment Share on other sites More sharing options...
StephaneS Posted August 13, 2018 Share Posted August 13, 2018 I have the same problem.... :-( Quote Link to comment Share on other sites More sharing options...
StephaneS Posted February 11, 2019 Share Posted February 11, 2019 Sorry, the demo version with Houdini Demo is working well now. My "houdini.env" is : PATH="C:/Program Files/Side Effects Software/Octane_4.00.0.21_Houdini_17.0.352_demo_Win64/bin;$PATH" HOUDINI_PATH = "C:/Program Files/Side Effects Software/Octane_4.00.0.21_Houdini_17.0.352_demo_Win64;&" Quote Link to comment Share on other sites More sharing options...
